Guess what I get to be the first versa owner to do.
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
bigdaddychia
Car: 2007 Versa 2006 Quest
Change an alternator. woot. 193k miles and its time for a new one.
Driving Instructor
Car: 2007 nissan versa SL CVT Red
wow, I was thinking I had lots of KM's 167 000 kms! Nothing compared to you! Any other major probs? Do you have a CVT?Are you using up any oil between oil changes?
bigdaddychia
I have regular auto. Change oil about every 10k miles. Not burning it though. ONly big thing i have done is replace the O2 sensors and the cats.
Andrews Chalmers
Car: Versa '07 SL CVT
Oil change every 10,000 miles?!
x4sper
Car: 2010 Nissan Versa 1.8S HB
ouch
bigdaddychia
Andrews Chalmers wrote:Oil change every 10,000 miles?!
I run synthetic. Not to mention in europe they dont change the oil nearly as often as we do here. Its all part of the oil company conspiracy to change every 3k. The alternator actually took a crap while I was driving so now its in the garage waiting for the new one to arrive. Luckily the rental place had a versa so I can still drive one.
NODES
Car: 2007 Nissan Versa SL (Blue)
bigdaddychia wrote:Change an alternator. woot. 193k miles and its time for a new one.
Mine may need replacing to a bigger one if better ground points and new battery do not fix my RPM's from dropping to low.
Codelicious
Car: 1989 Nissan 240SX
Mine does that too! It causes my car to shake! I was thinkin about getting a bigger alternator but I heard that it makes you have worse gas milage.. don't know if thats true or not though...
Couldn't we just make some extra grounds?
NODES
exactly the same happens to me. Upgrading the wires to 0 gauge is the cheapest and easiest to do so I will start there.
conversation
Car: Versa 1.8 S HB
bigdaddychia,
How many miles when u had to replace the cats? What were the symptoms? Were you the guy posting about the exhaust shops not wanting to work on your car? The search function is horrible on this site, so I have to ask here.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Talk about SUPER-Overkill.
4 gauge handles around 150A. 0 gauge does 300. I KNOW your alternator is not putting out that much current. And I'm pretty sure your system isn't drawing that much current either.
Have you guys looked into reseting the idle?
I need to jump back with another tester for the grounding kits to see if there's a need on the Versa. But I know for a fact that 0 gauge is way overkill.
NODES
I have 3 feet of 0 gauge wires laying around so I will use it up.
bigdaddychia
conversation wrote:bigdaddychia,
Yeah that was me. Symptoms a CEL. Came on at about 160k and changed em at 190K
We still need to do an article on this car. I'm pretty sure it's the highest-mileage Versa built.
scooterbob
Car: 2008 Versa, 1995 200sx
Not condoning this, but does the rental have the exact same alternator?
bigdaddychia
AZhitman wrote:We still need to do an article on this car. I'm pretty sure it's the highest-mileage Versa built.
After the first of the year. I have less than 3k till 200k
Cool. Start writing now.
williamk10
Car: '07 Nissan Versa SL
I did 2 out of the big three with 4 gauge wire. Still need to wire the alternator to the battery..but the positive battery terminal on the Versa is full of fuses. It'll be a pain in the a** to switch out.
Return to “Versa Technical Discussions”
