No, they most definately do not. There is channeling inside the caliper itself that provides hydraulic pressure to pistons on both sides of the caliper.Loveless wrote:understand that the stock one is single piston, and 300zx is 4 piston. Meaning that the lines needs to have a split to do the job.
splparts.com sells the conversion line you need, now in stainless steel braid
thats a confusing situation actually. 240sx uses banjo, z32 uses flare. skyline calipers are the same as z32 but use banjo. so which do you use? banjo seems fine? but flare is "proper?"AmoebAssassin wrote:
The conversion lines simply replace the banjo fitting on the end of a 240sx line with an inverted flare fitting that 300zxes use to attach the line to the caliper.
U just game them your 240's?cyrus240sx wrote:ehh 70 is good.... i got mine for i think 100 all together for rebuilt ones from auto zone after getting my core charge back
Yeah, correct. People manage to get away using stock 240 lines and grinding down the fitting or bolt a little so that the banjo may seal...however this is ghetto and prone to leakage. Let me remind you that ghetto and prone to leakage is BAD when you're dealing with your brakes! Do it the right way, if you have z32 calipers use the inverted flare lines, the price will at least be worth your peace of mind.black s13 wrote:thats a confusing situation actually. 240sx uses banjo, z32 uses flare. skyline calipers are the same as z32 but use banjo. so which do you use? banjo seems fine? but flare is "proper?"
i started a huge arguement over this on zilvia like a year ago, it never got resolved. it seems it really doesnt matter?
thats exactly my point though. skylines use "z32" calipers and banjos. did nissan do it ghetto? i wouldnt think so. i believe you have to remove a small seat inside the caliper, or grind the bolt to fit?AmoebAssassin wrote:
I dont really see your argument. Although i have no firsthand experience with skyline calipers, i will guarantee you that the line attachment area is DIFFERENT between z32 calipers and skyline calipers. Nissan as a corporation risks serious legal repercussions by bodging their brake systems, so while the calipers may be identical the fact of the matter is that skyline calipers were designed to use banjo fittings and thus the line attachment point will reflect this. A z32 was designed to use IF fittings and again, the attach point will reflect this. My point is that the best bet is to use whatever system the caliper was designed for. If you're using Z calipers, use an IF line. If you're using skyline calipers, go ahead and use your stock banjo lines. Personally, i wouldnt mix-and-match lines because that seems like setting up for brake leakage or violent depressurization. I'd rather spend 60 bucks on the correct lines than countless more after charging through a guardrail after my brakes go out. Im assuming that the zip tie comment was a joke, so i won't address it technically.black s13 wrote:thats exactly my point though. skylines use "z32" calipers and banjos. did nissan do it ghetto? i wouldnt think so. i believe you have to remove a small seat inside the caliper, or grind the bolt to fit?
either way, get stainless lines. banjo, flare, zip tie, it doesnt seem to matter.
btw, pretty good price you got on those calipers.
