BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Sun Jun 04, 2006 7:11 pm
I don't think its a good idea since RB25 5 speeds commonly go for $800-$900 IF you can find one. Now you have to add the $500 for the adapter plate, $300 for a driveshaft, $??? for linkages, shifters, mounts, etc.
The Mazworx kit is complete, Adapter plate, machine work, driveshaft, shifter, linkage, mounts, etc for $925. Now, you can get Z32 trannys all day long in the US from $300-$600. I got mine for $425 with 43K miles and a 1 year warantee.
The Z32 is just as strong as the RB25, the gearing is near identical to the S13, its readily available should something happen. The Z32 would end up costing less in the long run, and maybe even initially too. You know its a quailty products too, I believe their S14 is running one, and that car runs 9.43 in the 1/4.
