Guages don't work! =(
Nfire247
Car: 1990 240sx (s14 Ka-T)
sooo... none of my guages worked except the temp and most CEL/seatbelt/etc little lights when i bought my 1990 hatch w/ DOHC swap.
Found out my ecu was for a SOHC.. so swapped that out and now the tach works! It IS a DOHC cluster and the 5 wires from the ecu that are supposed to be run are run correctly.
Recap:Tach works, temp gauge works, if not all then most little indicator lights work,
speedo, gas gauge, and dash lighting does NOT work.(neither does rear defrost if its relevant)
This car has been chopped/cut and rewired, raped and harassed before i got to it. most of it is really crappily done too =(
I'm really hoping there is a common ground that isn't hooked up?!?
If so, where? if not, any other ideas?thanks
xX RB Xx
Car: SE3P, FC3S, FC3C.
i think your problem is somewhere in your post.
AZ89two4Tsx
Do you have any blown fuses?
Nfire247
AZ89two4Tsx wrote:Do you have any blown fuses?
I had one, the accessory fuse for the cig. lighter and whatever, but i've replaced that. All other fuses, at least the ones in the driver's kick panel, are all good.
xX RB Xx wrote:i think your problem is somewhere in your post.
lol good call....
Nfire247
anyone else?
Nfire247
Anyone else got anything? come on, thought this was the place to come for 240 answers!!
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
Nfire247 wrote:This car has been chopped/cut and rewired, raped and harassed before i got to it. most of it is really crappily done too =(
this is your problem. now quit posting stupid threads and go fix it.
/thread
Nfire247
/thread
thanks for the advice.. i'll go see if that works....
lol wut nope guages still don't work. hmm guess i'll have to try someone else's advice.. maybe i'll choose someone who actually has helpful things to say.now quit posting stupid responses and go fix it.. and by fix it, i mean drink bleach and don't reproduce.
