180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Oct 24, 2003 7:32 pm
Oil pressure/temp is easy if you've the little sandwich part that sits between your oil filter and the block as I know the greddy one has 2 ports on it that are sealed but can be used to plug in the different sensors or if you happen to be fortunate enough to have the greddy oil pan, there's another port there for the temp. Water temp is going to be a bit more difficult, you've got to use a drill and tap on some part that is metal (like the top of your radiator or enlarge the burping hole on your engine) and stick it in there. Another possibility is to punch a hole in your upper radiator hose and seal it up from there so it would resemble the blitz upper radiator hose for the SR in some way or another then when it's all dry and built up, put a nice hose clamp on it. Amp gauges, well that's just basically an ammeter that's got an analog gauge on it. So if that's the case, stick it in series on the power line you want to monitor.
