gauge cluster wont light up?
chmercer
i just recently put in a new headunit and my guages and surrounding miscellaneous backlit buttons no longer light up? i assume this is from some faulty wiring i did with the stereo, but could somone please help me remedy this? i just got all my speakers working and i want to go drive but its dark :(
edit - and yes i have played with the dimmer switch, i dont just have my lights off and dont realise it :)
edit - the car is a '95 240sx se
S13240
Try the TCU (Timing Control Unit), white little box under ****pit fuse box driver side kick panel. Might be burnt up!
quiksilvia
Car: 95 s14 se
either a wire crossed or u messed up ur wiring, check it all after making sure the fuse esta bien
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
You might have shorted a wire, which probably burned out your TCU. I know this, because I did it this past summer. I'm betting on the TCU, but I could be wrong. Check all of your fuses with a fuse tester, before you go buying other parts or tearing stuff apart.
chmercer
i am looking for this timing control unit you guys are talking about, but i cant seem to find any little white box near my driverside fuse box? there is a white plastic cover over some jumble of electronics that is about 3" x 6" but i wouldnt really call it little..?
btw this is in an s14, maybe you guys have s13s?
Got_Nissan?
:thinker just try banging on the dash really hard, lol.:D
chmercer
if you are going to spam do it in a different thread :(
chmercer
hm well i have checked and S14's dont have a TCU so does anyone have any ideas besides check all the fuses? also are there any other fuses that i could check besides the ones in the kickpanel and the ones in the engine bay? or maybe any inline fuses that i am missing?
nolaws4evr
Car: cruisin tha streets of Huntsville, runnin down hondas, tryin to get money out of my insurance comp.
ok, turn on your lights then go check to see if your tail lights are on. If they are, I have no idea what the problem is. If they are off then you have blown a fuse, i think 3rd down on the left line of fuses in your kickpanel. hope this helps.
Josh
chmercer
right on the money, i went through my fuses again and i am popping my tail light fuse. ive popped 2 so far, do you know what could be causing this? it sounds like youve had this problem before. (side note - my side markers and corner lights dont work either, oh man i hope this is all related cause i dont want to have broken my whole electrical system lol)
chmercer
update - it also popped a 15 amp (original fuse was a 10 amp)
HIGHLIFE
sounds like you have a wire crossed and it's grounding out. i'd go through all your wiring. you might have a wire touching your frame or something
J
rousie13
Yeah double check your wiring. Also, put a 10 amp fuse back in there. If it's rated for a 10, make sure a 10 is in there, otherwise you can cause some problems with the electrical system.
