gauge cluster not working?
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
03infiniti08
Car: 03 infiniti g35
hey everyone i got a 03 g35 and the gauge cluster on it is not working. No lights no nothing. It's getting no power to anything in the cluster but everything else on the car works just fine. I have checked and double checked every single fuse and that aint it. If anyone has any ideas i would be glad to hear them thanks.
pippen99
Car: 2010 Infiniti FX35 AWD
Disconnect the battery for a few minutes. when reconnected the BCM(body control module or also called BCU: body control unit) will be reset. If it happens again replacement of the BCU will probably be necessary.(BIG BUCKS) You will also lose your radio presets.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Welcome to NICO!
Were always here to help.
It does sound like you might have a BCM problem. The components involved in this incident. There are several things that need to be checked before condemning any component. If you have a multimeter and electrical knowledge you may be able to do this and we can help.
If it turns out to be the BCM you will still have to have the dealer program your keys or the car will not run.
Return to “G35 and G37 Interior, Exterior and Audio”
