cadet wrote:the flanges are all the same except for the turbine outlet, and I'm including the dump pipe and an hks gasket so thats moot.
this isn't the same as the CA turbo (compressor outlet, the 2 bolt flange) stock CA is a 3 bolt flange (as is stock SR)... where is he going to find something to bolt on here?
and he'll need something to bolt on here as well seeing that the CA uses a slip fit intake pipe...granted he's gonna need one of these if he uses any SR turbo too.
and I'm not sure if these oil lines can come off and you can use your old ones, but this doesn't look like it'll work either.
and unless you're selling them for under $100, I would stear clear. I know you're trying to push your stuff for sale, but its not exactly a bolt on deal, and its kind of a crappy turbo. My advice, don't get it. It's not worth the trouble of trying to fit it, especially since there are other turbos that bolt right on!
BTW, Here's one for $50 if you're set on buying one.
http://cgi.ebay.com/ebaymotors...&rd=1
Sean
