gtr brake hub conversion
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
Redb240
Car: 91 240sx
hi guys,basically i have a non turbo R32 GTS with 4 lug pattern and i am trying to do a 5 lug conversion. parts i already have are all GTR brakes, calipers, rotors, hubs/knuckles(basically the whole assembly minus the shock/spring combo off of a R32 GTR) and a set of GTR coilovers. so i am just wondering, what modifications are needed to make the rear fit? and are the fronts a direct bolt on with the GTR coilovers? thanks alot
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
go ahead and try it, im not to sure about the rear cvs fitting into the rear hubs but youll never know untill ya try, wats the worst thatll happen? your out of a car for a day?
themadscientist
Shocks won't work, rears are different. To my memory the fronts are the same.
As far as the brakes, I think you can just swap the hubs. If the car is HICAS and the parts are from a non-HICAS car you will have trouble trying to swap the parts, the tie rod is not the same.
Redb240
Car: 91 240sx
themadscientist wrote:Shocks won't work, rears are different. To my memory the fronts are the same.
i have a set of GTR coilovers, i dont plan to use stock suspensioni dont know if my car is hicas but the parts ARE from a hicas carwill it work? thanks!
themadscientist
Where the rear shocks bolt to on the bottom is different. Doesn't matter if they are stock or aftermarket. If it's for a BNR32, it won't bolt up on the bottom to anything but a GT-R, or a GTS-4 without modifications.
Odds are yours is not HICAS. This presents a problem. If you can retain the spindles and change the hub no worries.
Return to “GTR Forum / Skyline Forum”
