Nicksemianiw wrote:Alright guys have a question im runing the HD stage 3 ecu chip and its tuned for 444cc injectors and good for 280-300 whp. My question is this, I saw a flow chart from GTR injectors and they are
#1- 401 cc - 38.2 lbs
#2- 393 cc - 37.4 lbs
#3- 393 cc - 37.4 lbs
#4- 391 cc- 37.2 lbs
Now if GTR injectors are 444cc are they not suppose to flow near that? Not like 40-53 cc off of what they are rated. And then when I think about it can a 400 cc injector even get you to 300whp almost? I checked a injector calculator and it states that for 300whp with 4 injectors you need a min of 437.5 cc at 90% duty cycle and 414 at 95% duty cycle so whats off is are the injectors that were flow tested not putting out their normal amount of cc's or is the injector chart wrong or is it GTR injectors don't flow at 444cc? The thing is my ecu chip is for GTR injectors and I can't run bigger or less without some issues... Any adivce would help and no telling me NOT to run a chip won't help!
Were they ONLY tested or cleaned then tested? (as in ultrasonically, professionally cleaned).
What if you got some cheap Evo 9 560's and turned the fuel pressure down (Nismo Adj. FPR or Sard) to the equivalent of 444cc? (per the injector calculator)
