GTR/26 injectors in rb20.
90240sxca18
Car: 1990 nissan 240sx ca18det
will they just drop right in? what would i see as far as power/responce/smother with these on a rb20 with a rb25 n other suporting mods as far as intake manifold, exhaust, tuned at 12.5 psi ect ect. Thanks, and also anyone have any idea how much these would run me?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Check out the FAQ's The info is in there.
They will physically drop in, but you will need the resistor pack from a GTR or a V6 Accord.Not sure what year.Or check out radioshack, there's a write up in the FAQ section.
You will also need a tune for the injectors.Talk to Carlh, see if he can do something for you.
90240sxca18
i already have an SAFC to tune with, and im friends with 2 of the most renound tuners in the south east, especially in the AWD department as well as big HP supra's. so i get tuned by them on the loww.
90240sxca18
but thanks for the info buddy
BoostFab
Car: S13cp, S13fb, S14z
the 26 injectors will directly bolt on. but you will need resister box to properly run them.
pumpkin
as said before you will need a resistor pack, you can make it look clean by installing the resistors in a box
or you could get drop in injectors that are high imp.like the gtst injectors and not have to wire in resistors
90240sxca18
i already have a resistor for 6 injectors.
