allenms240 wrote:So, you want to buy a 20+ year old, motor swapped car to beat a 2006 GTO?
Traction is not that hard to get. Stiff damper with a med-soft coil. Then some 275 drag radials and your all set. I launched my KA-t at 6200 with 15psi and it just went with no spinning.S14toRPS13 wrote:The hardest part is traction. Get anything close to 300 whp in a 240 and you'll be spinning most of that power away.
spank044 wrote: I launched my KA-t at 6200 with 15psi and it just went with no spinning.
Yes, drag radials or slicks will help, but I get the feeling the OP is going to be running with regular street tires.spank044 wrote:Traction is not that hard to get. Stiff damper with a med-soft coil. Then some 275 drag radials and your all set. I launched my KA-t at 6200 with 15psi and it just went with no spinning.S14toRPS13 wrote:The hardest part is traction. Get anything close to 300 whp in a 240 and you'll be spinning most of that power away.
No vids, I did sell that engine to a guy on Nico about 4 years ago though. The only cam I had back then shook to much on the cage and never had that great of videos. I would really like to get a Go Pro HD motorsports cam, but don't have an extra $300 to spend on it. Those things have amazing watchable video even if the camera is being bounced around. Since then I've done a VQ35 swap and this winter I'm building it for boost.badbob2121 wrote:cool story, but in-car videos or it didnt happen
What particular part of Mexico will you be racing in? GR?Jmesl8er wrote:Going to be rolling races in mexico, street tires will be fine. His GTO is also an auto if that makes a difference
badbob2121 wrote:allenms240 wrote:So, you want to buy a 20+ year old, motor swapped car to beat a 2006 GTO?
Are you implying this isnt easily possible?![]()
I don't want to turn this into a KA vs SR vs RB vs etc, but I think he's better off with a SR. While compared to the SR a KA-T can make more power with any given turbo, the SR is more noob friendly compared to the KA-T.TheRealNap0le0n wrote:he only has a budget of 7k... so S13 coupe. KA-T build and enjoy
