im listening, also does anyone know what it takes to turn a sentra into an awd like the gti-rEpic_SE-R wrote:I have made an outline, any suggestions on what to add/take out,the order isn't %100, but i can work on that as i write it up
Gtir Swap-Pre buying the Gtir - -pros - -cons - -goals-Buying the Gtir - -price - -motor/motor, harness, ECU/Full clip - -Gtir dealer/ where to buy-buying parts/ parts needed - -list of parts needed - -list parts that you should get -prepping your car - -taking the old motor out - -making room for the gtir - -installation off needed parts (fuel pump ex..)-prepping the gtir - -clean up - -prep - -transmission - -wiring harness - -cooling system - -mounts-dropping the gtir in - -mounts - -harness - -transmission - -ECU - -Piping - -cooling - -gages - -vacume lines - -fluids-trouble shooting - -turn over - -start - -idle - -performance - -strange noises-helpfull links - -ga to sr - -gtir parts
