TheLocust »
https://forums.nicoclub.com/thelocust-u24501.html
Fri Jul 01, 2005 8:05 am
Hey guys, well heres the story. I love all motor hondas, my buddy has an 11 second all motor hatch(if anyone is interested in it I can give you links and more info because it is ungodly) I used to have an all motor high compression KA 240(sohc block mated to a dohc head/early 89 pistons/Colt cams/P&P head/port matched custom made 4-1 header/SR 370's and crappaly tuned on an SAFC by me) but taht was short lasted, I Was 16 at the time and it was my first car so I was kind of upset. yea yea, so 2 years later I bought another shell and put a red top SR20 in it. Right now the motor is basically stock, has hard intercooler piping, boost controller, full 3" exhaust and thats it. I just wanted a quick daily driver but I want a fast car again. and I've been wanting to start another honda project but I came accross an idea for the car I currently have. Right now I ahve the opportunity to buy an SR short block really cheap(50 bucks) so im gonna go all out if I do anything. A quick set up that came accross my head was this, SC61+supporting mods, 50wet shot, and GTi-R ITB's is the basic major parts of it. I don't plan to build the bottom end very much if any at all, after tons of research on this subject I found that the SR stock bottom end can handle quite a bit. My basic question is how efficient would the ITB's be on a forced induction car like this? And has anyone done this before? Im assuming they bolt up to the redtop RWD SR, they just need tuned really precisely correct? I only have tuning experience with SAFC, UberData and Hondata and have never touched a Power FC or Emanage my question is would I be able to tune all that and the throttle bodies correctly using an E-manage? Im pretty sure the FC could handle it but just wanna keep my options open. Thanks, I really want to think everything out before I start ordering stuff because its either this or the obd1 4th gen hatch I want to build which would be just nasty, Gutted Cut and Seam welded, stripped down wiring harness, spindle mount rear(no rear brakes) high compression built sleeved B20 block with a 1st generation B16A head hytech header skunk2 stage 3 cams ITB's good for high 10 second passes on slicks in a little over a 1000lb car tuned to run on 93. Now I know the 240 would be slower and might cost more money but it would be streetable and probally more reliable. Any thoughts? Im really kind of stuck on what to do here.. Sorry for the novel.
