GTI-R injector
Ca_Silvia
I just got my flow tested GTI-R injectors however, they never came with the harnesses. Are these plug and play or do i need to source out some injector harnesses?
boost_boy
firsttimeboostin wrote:I just got my flow tested GTI-R injectors however, they never came with the harnesses. Are these plug and play or do i need to source out some injector harnesses?
If the injectors have a squared end, they should be plug and play.
Dee
themadscientist
same injector as the RB26 444s, low impedance just like the CA18DET 370s, plug and play.
esetreceCA18DET
just placed ones on a ca18det yesterday, no problems, just minor corrections with safc, but just wondering how much hp do they stand?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
esetreceCA18DET wrote:just placed ones on a ca18det yesterday, no problems, just minor corrections with safc, but just wondering how much hp do they stand?
about 270-280 max
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
Using the formula cc/10.5=lbs/hr
(#lb.hr x # of injectors x safe duty cycle for top feed injectors) / BSFC(Brake Specific Fuel Consumption)
So you could run them at 100 percent, but these are safe limits.
GTR-444cc/10.5=42.3 lb/hr
(42.3 X 4 X .85) / .55 = 261.5whp
CA-370cc/10.5=35.2 lb/hr
(35.2 X 4 X .85) / .55 = 217.6whp
You are spot on C-Rad. Hope this equation helps you all determine what size injectors you need. Might as well post 550cc's too I guess, hold on...
550/10.5=52.4
(52.4 x 4 x .85) /.55 = 324whp
Dont blow your **** up!
