That's true, but then I have to figure in the extras to get it running. The local shop that has the Avenir has it priced at $1600 bucks. Which is a good price no matter how you look at it. But then I need to get an intercooler plus piping (the shop has the Avenir's FMIC, but I don't know if that's included in the 1600), then I need to get a boost controller, a gauge or two, I assume a clutch that's rated for a higher output (this true?) and then get a 3" inch exhaust system done up. So it really starts to pile on.RED_DET wrote:VE motors still cost 1500-1700. You can get a DET for that amount as well.
And actually, I already have a JDM engine in there, so that money would go to a shop to install the cams. Are cam gears even necessary?RED_DET wrote:
JDM SR20:$400Header:$200(SS Auto Chrome header)Cams: S4 cams, $400 used $550 newExhaust: $400ECU: $550 (straight from JWT)Pulleys:$200
Almost 1k less than the VE swap. 160-170whp.
