W O T »
https://forums.nicoclub.com/w-o-t-u75991.html
Wed Mar 25, 2009 6:31 am
I just did mine on the 3.5 about a month ago
Pretty easy (if you do it my way). First take a peek and see where all the ignition coils are (there all visible)
Passenger side is a breeze, 10mm and a plug socket is all you need. Drivers side is "tricky", 2 plugs are no problem, but there one directly under the throttle body. When I asked here if I had to remove my t/b everyone said yes, I guess cause the manual says to, but I found a MUCH easier way.
You gotta take out your air box first anyways to get access, but right under the t/b, theres a little black/blue unit (IACV) thats held on with 2 screws, undo the harness plug and wiggle it out
DO NOT pry it with a screwdriver, it was tight in there and took me a minute, but there is an oring right at the seal, dont wanna damage it. After you pop that out you can pull the ignition coil and plug no problem (its tight, but no half a** stuff required)
Or you can opt to pull the t/b off and have really easy access, but thats alotta work. Your choice
And as for spark plugs, I cheaped out and went the free way, my buddy gets champion plugs for free, and they make an expensive plug for the vq so I got them from him. Work just fine so far, and they only retailed for like $10/each
good luck
