WDRacing wrote:The GT35R isn't a good turbo for low boost...however.
You guys need to put down the crack pipe. This thread is riddled with bad info and BS.
Go ahead and run the GT35 with the FMU, just retard the timing. Unless someone can tell me EXACTLY why that's a bad idea? The 35 CAN put out more volume then the T25...CAN. But 8 psi is 8 psi, in fact, the 8 psi from the 35 will be quite a bit cooler then the 8 psi from the T25, cause it's not nearly spinning as fast to gen up that amount of boost.
To the OP, read more.
WD
Are you serious? I thought we got past this myth in like in 05 or something. NICO ka-t, get with the times!
8 psi is not 8 psi. what matters in terms of fuel requirements is air density. that means pressure AND temperature. the cooler charge of the gt35 increases the air density(compared to 8 psi from a t25), meaning you need more fuel for proper afr's.
it just so happens that a rrfpr will work just fine at 8 psi.(i have a big boy spreadsheet that tells me so) Use a 6:1 RR. that will give you the best afrs. (with 100 psi in the fuel rail)
i wouldn't say this thread is riddled with bad ideas and bs. this thread has cautious members who don't want another member to do something stupid.
read more.
