gt35r ka24de fitment issues
jonas92
Car: 90 240sx KA24DE-T Weekend Warrior
85 z31 RB20DET Track Rat
98 EK9 DD
im haveing problems with the way my motor sets in the car.... the motor itsself is leaning to far to the driverside and is causing my turbo to get into my master cylinder... but my transmission is too far to the passenger side.... like 1st is were 3rd usually is?? i have a s13 ka24DE with a sohc trannny so i cant just tilt the motor towards the passenger side or the transmission will bee rotated too much?...i removed the turbo and now the motor transmission is good but the turbo is still getting into my master cylinder :confused:
azka24det
Car: 1991 Nissan 240sx Hatch
what kinda mounts are u using? Might wanna try some solid mounts to hold her in place.
terry_240sx
Car: '93 240sx hatch
azka24det wrote:what kinda mounts are u using? Might wanna try some solid mounts to hold her in place.
yep what he said.
or even get replacement oem engine mounts and transmission mount
or nismos :biggrin:
it could be because your mounts are too saggy/floppy?
jonas92
98 EK9 DD
is there an after market solid mount?.. or should i just make some flexane ones like the 240sxtech.com guy did?
jonas92
98 EK9 DD
JDizzle
Car: 1995 Nissan 240SX
Some of the cast iron manifolds only allow you to use on center housings. What manifold do have?
jonas92
98 EK9 DD
ebay top mount:)
Pro ViZion
Car: 1990 Nissan 240SX w/ KA24DE
+1 on motor mounts. It shouldn't sit like that.
I just did a motor swap and on the old motor the driver side mount basically was broken in half. They are getting old now.
nofatchicks0073
Car: 91 hicas RIP
92 hatch RIP
89 hatch parts
90 hatch in the works
i concur the mounts on these things are getting old ive pulled motors from two of my 240's and replaced motor mounts both times i just went with oe though
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Oe is just fine, there is a Guy running an 800hp SR on here running stock mounts. Maybe get beafy trans mount though. Have you put them in yet?
dgms240
Car: '90 s13 hatch ka24det
Get some nismo engine/trans. mounts! There not too expensive (less than $200) and stiffer than stock.
jonas92
98 EK9 DD
i bought some hockey pucks yesterday lol
biggie
Holy continous thread revival.
