Largekid »
https://forums.nicoclub.com/largekid-u8186.html
Fri May 09, 2008 1:59 am
.63 is where you want to be as far as lag and such..., Last season I was running a Garrett T04-S (60-1) turbo, .63/.63 iirc, on 22lbs of boost. Id hit full boost by 3400. I made 420whp w/ that setup w/ full boltons and a very restrictive downpipe and horrible tune. I'm not sure what you consider "good" power, but that turbo, w/ all the supporting mods, should get you upwards of 400whp pretty easily. I think you'd like that turbo if you want to be around there. How much boost you plan on running? Is the motor built at all? Do you have all the supporting mods to help out w/ this turbo?
