http://www.turbobygarrett.com/...3.htm
LoL That sucker will hit 350 without a problem if that's the same turbo. Compressor seems to match the same specs as what you gave.. If you can get this sucker for a good price Grab it.
Looks like it bolts right up VIA to your stock manifold. Spool should be ~ 4000-4300. Which is Pretty damn decent.
Of course you'll need to fab. some pipes for ur intake/hot pipe. You'll need a front mount if you do not already have one.. and a new fuel pump... etc...
You'll need an oil feed line as well. I'm not sure if the coolant lines will line up though. Only downside i can really think of. And that's just a Maybe.
Eh also check out if it uses the same bolt pattern for the exhaust ext./elbow.. Should be the same being that it uses the same T25 house design.
zerothread?id=84198http://forums.nicocl ... 16461(lazy lol, lucky im interested in this tubo(found those links using search))
Modified by heavy1metal at 3:21 AM 11/27/2005
Modified by heavy1metal at 3:35 AM 11/27/2005
Modified by heavy1metal at 3:36 AM 11/27/2005
