In case anyone wanted to try out the car I use:
Spec for the S13 in the video
http://flohtingpoint.net/drift/pilot.avi and
http://flohtingpoint.net/drift/subtraction.avi
Car: Nissan Silvia 2000cc (color: grey =P )
Mods:Suspension and Brakes----------------------------Full Customize Suspension-Sport Brakes-Brake Balance
Engine and Intake System----------------------------Racing Muffler-Racing Chip-Full Engine Balancing-Port Polish
Drivetrain----------------------------Triple Plate Clutch-Racing Flywheel-Carbon Driveshaft-Fully Racing Trasmission-Full Customize Service Limited Slip
Turbo----------------------------Stage 1-Stage 2(the reason I have both is I switch to stage 2 when I'm doing wide open courses like apricot hill, but I use stage 1 for close courses where I want as little turbo lag as possible)-Racing Intercooler
Tires----------------------------Simulation
Stability & Control----------------------------Lightweight stage 1
***Tuning***Spring Rate: 3.4/3.2Ride Height: 93/92Shock Bound: 6/7Shock Rebound: 6/7Camber Angle: 2.6/1.0Toe Angle: -.5/.5Stabilizers: 3/3
Brake Balance: 7/24
Limited Slip Initial Torque: 50Limited Slip Accel: 50Limited Slip Decel: 15
Gear Ratio:1st 4.0022nd 2.8743rd 2.1174th 1.6165th 1.2406th 1.067
Final 3.775
Active Stability Management: 0TCS: 0
There you go, enjoy =)
Regards,floh
