GT28RS what ar to pick .86 or .64
Grambos13
You red the title. I have a redtop w/600cc in injectors/z32 mafs/greddy front mount.... in the end I want a 300whp track car/drift car. What do you guys think?
Grambos13
the ar I am talking about is on the turbine side .64 or .86
The reason I ask is I just got one for a good deal and the AR is 0.60 on the compressor and 0.86 on the turbine.
DawgMode
Car: 180sx
.86 for crazy topend...but laggy.64 will spool quicker for good low end
Grambos13
Thanks. Is there any way to change it? or do you have to get a completely different shaft/wheel/housing?
Nicksemianiw
Car: JDM 89 Silvia K's
You can add some things onto your car to reduce the lag for the .84 A/R i dont see a problem with the .64 A/R though. You can add a catback exhaust,test pipe,down pipe,turbo elbow,turbo manifold,hotpipe,smoother flowing intake and get some nice tuning done and that can lower the lag considerabully, because the smoother the flow and bigger piping will reduce back preasure which will help your turbo spool faster. And if you want a big differenct go with a smaller i/c core a 12x9x2.5 if you dont want that much power then that would be good. will all of that you would notice a big differenct in the lag.
Grambos13
Good deal...I'm just gonna go ahead and use it then. I allready have all the stuff you are talking about besides the smaller ic but I want to keep my greddy. The only thing I do not have yet is a good boost controller. Can you adjust a electronic boost controller to make it hold the wastegate shut in the lower rpms then have it back off when it gets up to full boost speed?
PhoenixTurboEric
Car: em1
IMO, i would go with the .86 a/r just so you dont limit the flow of your turbo, remember people always want more power!
Modified by PhoenixTurboEric at 9:07 PM 5/21/2005
Grambos13
It just came in the mail today it is the .85 ar. Do I need any type of oil restrictor? I am using my stock t25 lines that I was using on my previous t28
PhoenixTurboEric
Car: em1
Grambos13 wrote:It just came in the mail today it is the .85 ar. Do I need any type of oil restrictor? I am using my stock t25 lines that I was using on my previous t28
No need for the restrictor
s13sr20chris
whoa, whoa, whoa...the .86 is laggy? maybe on a turbo with a big compressor. check the specs on the gt28rs. it has a little compressor(a good one though). i would never ever get the gt28rs in .64. you have to special order it from most places because they only stock the .86.gt2871r, whole nother story. that is a compressor wheel over 10mm bigger.
Grambos13
Thanks for clearing that up. I'm glad I got the .86. I'll let you guys know how it works out for me after I get it running tomorrow. All I have left to do is fab up a new peice of intake tubing for my air filter and I should be good to go
