It is a new turbo, but I've had the problem all along. it is the actual flap itself, because when I take off the actuator the flap will open ~30 degrees vs the 90 it should. I do have an adjustable w/g set to as low as will go, but I had a stock one on there I traded out for this one.. Same problem :/johnnyballs180 wrote:is this a new turbo for you, or a new problem? my first guess is that you have a pressure leak. if there's a leak, then there's nothing to force the wastegate to open.can you move the actuator by hand? it should be a bit tough. where do you have the w/g signal from? is your w/g adjustable? and do you have any kind of boost controller?i'm looking at a pic of the disco potato, and i think that the divider plate would had to have been smacked or bent to block the w/g flap.
i'm just guessing though
I'm not sure what exactly you mean by pressure source, it being a turbo its the exhaust..? It doesn't have any leaks- its on there tight and the elbow has the gasket on there.Thoughtful_One wrote:Check the FSM. They have a method in there to check the wastegate to see if it's functioning properly.
I just checked the RS, and it doesn't have a divided wastegate exit so it really shouldn't be getting stuck.
Make sure that the connection between the wastegate and the pressure source does not have a leak.
Where is your pressure source?
I'm 99% sure the wastegae as far as the npple is hooked up correctly. I know it is hooked up to a "T" that connects it to the BOV and then back to the throttle body.johnnyballs180 wrote:i think Thoughtful_One means the boost source that the wastegate's getting it's signal from. on your wastegate, there should be a little hose going from it to something... do you have aluminum piping? front mount intercooler? or the stock one? i don't remember 100%, but i think on the plastic pipes that came with the motor, the one going FROM the side-mount intercooler to the throttle body, there's a little nipple that the wastegate's pressure hose is clamped onto.
if you have new piping or a new FMIC, then it kind of depends. on the GReddy ones, you usually have to make your own tap, or you can "T" off that hose to another hose coming from the top right (top right, right?) nipple on the throttle body.
if you're not sure, take a pic and post if for us i'd be happy to brainwash you. lol
FSM is Factory Service Manual; it's kind of hard to find one (especially in english) for the 180/Silvia SR20DEt.. here's a link though:http://www.nicoclub.com/FSM/24...T.pdf
its in japanese, as you'll discover. haha
real quick... are you able to move that flapper by hand? not with the wastegate actuator rod, but the flap itself?
