GT28RS safe boost level?
Grambos13
I was wondering what the maximum boost I should be running with out messing up my engine/ turbo. The car is not going to be daily driven. THe engine specs are: new bearings, gaskets/seals, new rings, rocker arm stoppers, 600cc injectors, mines tuned ecu, greddy front mount, greddy intake manifold...
BaliLover
I ran 18psi on mine with a stock USED motor, no rebuilding what-so-ever, with rocker arm stoppers, FMIC, 3" exhaust, stock intake manifold, and rocker arm stoppers. I had my motor specifically tuned for it though and I would suggest that you do the same. I got 315RWP out of my setup with no problems.
Grambos13
Nice...thanks for the feedback
Grambos13
What do you mean by specially tuned? Who tuned it for you and what did they do?
Grambos13
BRshh sdottu I'm really ****edy up
Grambos13
haha my bad
mackdaddy240
Car: High performance with a clean look.
with your tune did you use the 370cc injectors???? I have a Prom chip and a ka24E maf, I was wondering if 12-16 is safe for stock ecu tune and 370s?
Modified by mackdaddy240 at 11:17 PM 5/29/2006
96EclipseGST
Car: 1989 240sx w/ SR20DET
mackdaddy240 wrote:with your tune did you use the 370cc injectors???? I have a Prom chip and a ka24d maf, I was wondering if 12-16 is safe for stock ecu tune and 370s?
wouldnt recommend it
