GT28RS oil restrictor
Grambos13
I have a GT28RS .86ar that I am putting on my SR. I was wondering what size of oil restrictor I need to use and where do I get it? I am going to use aftermarket braided lines.
silvia_ca18det
Car: 350whp ca18det drift silvia
this is a very good question! i was JUST about to run a stright braided line to my gt28rs when i heard from garrett that the seal can only tak like 8-10 psi? i would like to know this aswell
Fenvy
Car: 2005 350Z Base 6MT
hm, does it apply to gt2871r .64 also?
Grambos13
I would think so because they are basically the same turbo
silvia_ca18det
Loveless wrote:hm, does it apply to gt2871r .64 also?
they told me it is for all their ballberring turbos!
Grambos13
so can anyone answer the origional question?
574-240sx
Car: Nissans, Toyotas, Subaru
Some KA-T guys are using oil restrictors, there was a thread over there recently I believe. Don't know if that helps but I will try to find it.
574-240sx
Grambos13
Thanks 574 that did help. It looks like you need a 1/16 restrictor. It is just a brass or stainless fitting that you can screw in to the turbo inlet then attach the feed line to. Seems pretty simple to me.
codyace
Car: S14 w/redtop
Yes.
A simple search would have yielded you the information.
.035 is the restrictor size you need.
ATP TURBO sells the lilttle brass fitting for 12 dollars
EDIT: Took that wacky link out for the gt28r....not sure why I copy pasted that link!!
Modified by codyace at 12:42 PM 9/13/2005
goldollar
Car: cars
You can also drop to a -3an oil line and that would do the trick for you as well.
codyace
Car: S14 w/redtop
-3 line is nice too, but you should still get the restrictor.
Nowhere
Car: Suzuki x-90, samurai
goldollar wrote:You can also drop to a -3an oil line and that would do the trick for you as well.
A 3an an is 3/16"
The XX-an , the an is always a 16It's X/16..3/16 = .1875, HUGE for a restrictor.
.035 male/female restrictor....
ATPTURBO.com wrote:Oil inlet fitting for GT Ball Bearing Turbos for GT28R/GT28RS/GT30R/GT35R with built-in oil restrictor (of .035 hole size).
Grambos13
where is a good cheap place to get oil lines?
codyace
Car: S14 w/redtop
Find new or used Taka Lines for your specific application....
And again, to quote myself from earlier, just get the fitting from ATP...(oh and Nowhere basically repeated me, so follow his advice as well!)
VitaminT
Car: 93 240sx SE
I think the Taka lines have a restrictor built in but I am not sure.
