MrSoutherland wrote:It's not a simple as you think it is. Even just keeping the boost at a low setting! You NEED:Supporting injectors, Intercooler, ECU tune, Exhaust mani for your new turbo.... Couple other small things too. I had to butt in seeing this thread was making it seem like you just slap a turbo in and your good to go. However with those items matched up with the turbo of choice is the goal in mind. AND- Don't buy an ebay turbo!
true true true. I mean you asked about running 14 psi. yes that would be fine if you have the supporting mods listed above. i personally run 19 pounds for my high setting and have the waste gate set for 13 for my low. but i have what mrsoutherland said and then some so....
