There are some easier solutions to the GT2871R installation. Clocking the turbo you cannot avoid. As far as the pipe mods...check out the group buys on Zilviz.net. There is a guys that makes an intake pipe for the 2871 for cheap and adapting the charge pipe is a snap with the right coupler. The oil return on the bottom of the turbo is different then a s13 SR but all you have to get is a S14 return flange and it bolts right up with no modification.goj_cloud wrote:now could someone clairify that this turbo is bolt on for the s13sr. Ive heard people saying its bolt on ive bheard people say its not. so is the gt2871r bolt on to the s13 sr20det
Yeah I picked me up a new turbo. Ouiton you HAVE to get one of these 2871r's. They are swell LOL. I have a ceramic bladed T28 from the Skyline GTR R33. Once I put my 2871r on you'll be the first in line for it. Hit me up on my email and I'll give you the run down.leroiboy wrote:hey ryon what's up man. so apparently you have a new turbo. any chance you have your old one still. condition/what kind/price. thanks player
vlsd rear and 235/60-15 drag radials....1.51 60'...thats where it's at....ILikeMy240sx wrote:that's some sweet 1/4 time? What kind of tires and rear end were you running on?
if you use the factory bolt you are cool....but at the same time if you use a stainless steel line setup...the adapter that bolts into the block for the line is a small enough inside diameter to do the same job.goj_cloud wrote:i also heard somthin about a oil restrictor bolty what do they mean
forgot to tell you that the newer style is capable of 75hp more then the older one and all without sacrificing anymore spool time..goj_cloud wrote:were can i order a newer one at and how dooes the newer one differ from the old one other than the bolt
Nope...there are acutally 4 versions of the gt2871r...karmakaze wrote:your talking about the gt2876rversion 2 is the .86 and version 1 is the .64
472560-15 460hp .64 or .86a/r no actuator, bolt flange on outlet743347-1 400hp .64 or .86a/r slip fit outlet743347-2 475hp .64 or .86a/r slip fit outlet771847-1 460hp .64 or .86a/r bolt flange on outletgoj_cloud wrote:okay i dont want the 86 i wnat the 64 just tell me what the new one for the 64 is called
the 71rredtop91 wrote:^ Just to clarify you are referencing the 2871R rather than 2876R correct?
wit so there is a 2871r that looks like the rs whats the catchredtop91 wrote:The adapter P2M sells is for the 2 Bolt style inlet that is common among T28 style OEM turbos. The GT2871R doesn't have a 2 bolt inlet in most cases (Unless you get the RS style) so you wouldn't need it.
