There is about a 300 - 400 RPM difference between the .86 A/R GT2871R and .63 A/R GT3071R from what I've seen.Tipripping240 wrote:So is the 3071r gunna be a laggy turbo or will it have good power all the way through? Im looking for the same numbers (400whp) but i need to know if a 3071 or a 2871 is gunna give hard boost at top or bottom or all through out.
No, but you should be upgrading the manifold at that time anyways.nissanrcer240 wrote:Does the gt3071r use stock lines and manifold also like the gt2871r?
So i have heard that tubular manifolds are bad cuz they crack. What is a good manifold for that turbo? (3071r)Nismo_Freak wrote:
the crappy ones, yes. If you want reliablity, your going to be spending between $700-$1100 on a great manifold.Tipripping240 wrote:
Good news, in the very near future we will be offering the 2871R in a T3 Turbine housing with a 4BOLTspanishricer wrote:Well I'm going to be upgrading the factory turbo after summer and am currently going through the planning phase. My goal is to have 400whp and maintain daily drivability.
Now the original plan was going to be a GT2871r w/.86 a/r tuned along with a Greddy IM and HKS step1 cams. I thought that would get me very close to 400whp if tuned correctly. Then I noticed that there's a GT3071r w/.64 a/r that is capable of 425whp. It's a little bit more expensive than the GT2871r, but I would probably skip the cams if I went with this turbo.
So which would be the easiest route to reach 400whp? Would I be able to run lower boost with the GT3071r and still reach my goals, compared to running higher boost with the GT2871r? Any input you guys have would be great.
Just wondering what your reasoning is for this?s13sr20chris wrote:well, if you want a t25 flange then you are stuck with tiny turbine wheels and you should keep a modest(sub 400) hp goal. big power on tiny turbines makes for freaky cars.
Our Topmount/downpipe combo retains a/c and powersteering!!! http://store.yahoo.com/cheapturbo/pesrexma.htmlspanishricer wrote:Well I planned on upgrading the manifold at the same time, but also forgot to mention the main reason I'm looking at either the GT2871r or GT3071r is because both are available with the T25 housing and with internal wastegates. That way I can go with a tubular bottom mount and avoid having to fabricate custom piping both entering and exiting the turbo and cut costs.
Either way you look at it you will get a sharp rise in power with any small displacement engine pushing twice it's stock power.s13sr20chris wrote:the problem is now you have a car that goes from 0 boost to full boost really quickly. thats ok for the street and a good driver. its not so hot if you need good control over your power output(like road racing). better when road racing to have linear power delivery(like a quality na motor) to avoid tire roast at corner exit. thats why i reccomend this order...1)size compressor for power goal2)find ideal turbine for compressor size3)adjust turbine size minimally to get a reasonable spoolup.
If I understand you... you can read a compressor map to determine the flow and compare that to your engines required flow (based on VE) for a given HP number.s13sr20chris wrote:...1)size compressor for power goal2)find ideal turbine for compressor size3)adjust turbine size minimally to get a reasonable spoolup.
the last step is only nescesary because a big t4 turbine would be hard to spool on a little 4 banger.
its less exact and im not really an expert on it. the point is you want to keep the sizes of the wheels fairly close. i am guessing thet a turbine wheel should be about 90% the diameter of the copmressor. thats about the ratio that the really well matched turbos have.Alfa Turbo wrote:
But... how do you go about #2 and #3?
-Brian
BTW I am running a tangential divided T4 on a 2 liter now... Getting 290WHP out of a T3 S compressor @ 15psi but do not see that pressure until 4300-4500rpm.
