r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Sun Dec 13, 2009 10:58 am
Yes Greg, while that may be true you are overlooking the fact that you lose 1 bar for atmospheric pressure when you run a MAP sensor. A 1 bar map sensor would be what you would use for a naturally aspirated car, because it goes from zero to 14.7psi (vacuum to atmospheric pressure). For pressures over atmospheric (i.e. forced induction) you are going 14.7+ (1 psi for each lb of boost you run). If you have (like me) a 4 bar map sensor, you get 14.7 x 4 - 14.7, to compensate for atmospheric pressure. Your math would be correct if we were in a vacuum. 14.7 x 3 = 44.1psi. Idiot.
Also, my map sensor cost me $40. I can't even buy an eighth of weed for that.
