GT2871R oil return line problem
apocalypse
For those that have this turbo, what did you guys do get the oil return line right?
I tried using the stock flange but the hose ended up touching the steering shaft.I then tried to cut the metal tube on the flange and braised it at an angle and that didn't work.So, I bought the gt oil drain kit and that still doesn't work the hose just kinks and backs the oil up in the turbo and smokes like a mofo.And thats where I am at now.
sean58888
Car: 91 240sx coupe
you have to use the s15 t28 turbo's oil return pipe,here is a picture of it............ http://cgi.ebay.com/ebaymotors...76028
Geno750
Try reclocking the turbo and lining up the drain flange? Thats what I had to do for my GT2560.
karmakaze
Car: 98 240sx SE
Geno750 wrote:Try reclocking the turbo and lining up the drain flange? Thats what I had to do for my GT2560.
you can get a new flange and gasket from ATP turbo.
