fortwayne240 »
https://forums.nicoclub.com/fortwayne240-u41562.html
Tue Aug 29, 2006 7:47 am
Oh, you will also need to make sure that you get a wastegate for the T28 series of turbos (straight arm, no bends).
Some vendors include a wastegate with the turbo, some do not. You will need to clock the turbo, and then custom fab a wastegate bracket that holds the wastegate in the correct position.
Your best bet is to call around and find out which business (enjuku, heavy throttle, JGY) sells the turbo in a "bolt on" style, with all the bracketing and clocking already done.
I am also going to recommend the TAKA turbo lines, or make your own, but the factory coolant and oil feed lines dont like where the T28 Family turbo sits. I am sure that with a little bending.....
I tried to use the wastegate bracket that was included with the turbo, but it actuallly broke under high boost conditions, so I had to make my own from 1/4" steel.
