IHeartRPS13 wrote:Wouldn't cometic hg be cheaper and do the same plus just swain coat and extrude hone for the mani. should cost the same as a tomei and wont crack ever or this might be wrong but wouldn't the ichiba ver2 work the same as tomei without the price tag. just suggesting to save some money please correct if i'm wrong btw is the fpr necessary or suggested?
Cometics take too much work to get a proper seal. Cosworth have proven to be great headgaskets at they're not too expensive.
Tomei's, Ichiba' and megan manifolds all crack eventually. The extrude hone porting and swain coating method will probably run a little more than a tomei manifold, but is definitely worth the extra expense. I suppose you could save a little by opting for ceramic coating...maybe?
