gixxerbob »
https://forums.nicoclub.com/gixxerbob-u80630.html
Wed Feb 04, 2009 8:44 am
I would like to start this thread by saying that I only want to hear from people who have pushed the gt2871r to its highest power capabilities, I only say this because there is too much riff raff on some threads and people giving opinions with no research or experience behind these statements. If you have never owned a gt2871r then you probably shouldn’t post but if you know your turbo talk please add to the thread
DO NOT (yea I used caps haha) don’t ask if I have ever driven a 2600lb car with 450whp, or say that I don’t need that much hp or any other stupid comments. Including “you should focus on spool or the entire dyno graph not just the peak” although that is not a stupid statement I realize this already but want to focus on a whp goal. Please give me some info behind your statement (don’t just say “no”….say “no, because the ….”.)
To those of you who are qualified to give advice i would like your insight on a few things i am unsure about, but feel free to comment on things that i have or plan to buy listed above.
I have followed almost every gt2871r build thread on nico, f/a, zilvia… it is obvious that this turbo has pushed 420+ hp with the .64 a/r turbine housing but I want to push it to 450, possibly upgrading to the .86 but not if the .64 is thought to handle 450.
I drift occasionally when I can get a group of 240 guys together but I really plan to bring the car to VIR and autocross days when I can this upcoming summer but 99% of the time the car will be a street monster off of red lights and making more expensive and newer cars look bad. haha My set-up These are the parts I already haves14 sr20det zenkiGreddy 1pc new style intake manifoldGreddy m-spec Koyo radiator F-A-L fans Samco hoses Nismo thermostat Nismo fpr Z32 fuel filter Z32 ignitor chip Power enterprise oil filter Motul 5w40 Spec stage 3 clutch Spec street flywheel Valve guide seals Megan down pipe Megan test pipe HKS hi power exhaust Innovate wideband B&M fuel press gauge megan boost/oil press/oil temp/water temp gauges megan manifold dei header wrap z32 transmission and lower harness shimmed z32 diff walbro 255 greddy rocker arm stoppers oem oil pump oem water pump ngk iridium #7 oem timing chain tensioner nismo radiator cap still have to buy power fc d-jetro with map sensor kit and boost controller mazworx transmission adapter aluminum drive shaft apexi head gasket Arp head studs Gasket set Brian crower springs Extrude hone turbine housing Mobil 1 transmission oil 3qts Turbo timer cp pistons/eagle rods/apr rod bolts acl main/rod bearings arp main studs bore, hone, tank, linebore, deckhead, deck block, polish, balance, mic crank, cut flywheel freddy oil pan oil filter relocator and cooler catch can turbo timer synapse bov greddy turbo elbow
I was thinking of going with the jgy gt2871r kit with 72lb inj and top feed rail but unsure of the injectors, who makes a 60lb mototron adapter kit for my greddy manifold any more since I could not find a HASS kit. Or what other options would I have for a higher impedance, lower lb injector that would fit my greddy manifold even if I use 4bar fuel pressure instead of 3bar and work towards a 450whp goal
i plan to boost the hell out of the motor, i was wondering where the maximum efficency of the gt2871r lies as far as psi and whp. ( .68 and .86) (going with the 56 comp trim)
9:1 or 8.5:1 since I will be doing high psi with a reasonable flow I have been planning/ researching/collecting parts for 6 months now. Recently a friend of mine has chosen to build a redtop gt3076 but I want to show everyone that more research behind a gt2871r build can be more efficient than a high dollar top-mount setup. (i really want to show him up and make him look bad haha)
what cams, I know codyace like the s3 cams but im going to shoot a little higher whp, I was going to buy s3 cams if I could find them used or brian crower 264's if I go new because the s3's are so much...would you recommend s4 or c1's hks bc toda…? . Thanks for reading and any valuable input that you post -rob
