Without cams, it's hard to say. I'd agree with the above poster at roughly 320-340 at 18-19 psi. I would also warn you taht your injectors are on the edge of being maxed out there. No more than 350 wheel should be safe IMO on them.
With a nice set of JWT cams, larger injectors, 20 psi...potentially 370-380.
supreamS14 wrote:well the 550cc are good for 400whp on race gas
Race gas vs pump gas has nothing to do with injector size.
supreamS14 wrote: so if you have the 86 A/r
He's got the .64. .86 housings are laggy and not fun.
supreamS14 wrote:dyno tune it around 300 whp on pump gas and 400whp on race gas. You should be @ 300 whp at around 15-19 psi.
400 is doable on pump. Why run race gas when you can run a Meth Injection kit?
