i took a video of my actuator. I "T"ed my boost gauge to the actuator and a portable tire compressor. this is the result.
http://www.youtube.com/watch?v=QHcy8sWihCs
is my actuator arm not moving far enough?
I also drove with my boost gauge "T"ed into the hot pipe vacuum source and the wastegate actuator.
my boost gauge went all the way to 1.3 bar. using my power FC i was able to let off the gas before boosting too much. with the power fc, i hit 1.25 bar. so, this means that my actuator is seeing at least 1.25 bar.
I'm going to try spinning the actuator arm 180 degrees to see if it can open the wastegate further... i'll have to wait till the turbo cools off
