exode »
https://forums.nicoclub.com/exode-u48159.html
Sun Jan 07, 2007 9:43 am
the .64 will make those numbers easy, and if you were running budget and wanted to add onto that motor i'd do this
Good 2.5" exhaust, get brand name but you can get it usedGT2871R .64 a/rAftermarket o2 housing, ebay will suffice for $8050lb msd injectorsSAFC II for tuningWalbro fuel pumpz32 maf
You should make those numbers right under 20psi with a good tune (i can hit that at 16psi), over 20psi will be pushing those injectors. Anything over 600cc injectors you will have to do a rom tune which will up your budget around $400
But there isn't a big price difference with the .86 and the .64, its a matter of boosting at ~3300 rpms or ~4000 rpms, and that all is based off what your driving for (86 for drag 64 for drifting, whatever its debatable)
good luck
