gt2871 question
DLYNNW
Car: 89 nissan S13.5 97 Kouki s14 06 toyota Bb
how reliable is the gt2871 turbo for daily driving and what is a good set up to make it a reliable setup.
what all do you need done to run a gt2871 someone help me out i wanna upgrade my stock redtop to run a gt2871 what should i go with. :mike
DuckyD
Car: 1995 240SX
DLYNNW wrote:how reliable is the gt2871 turbo for daily driving and what is a good set up to make it a reliable setup.
There is argument about the current state of Garrett turbo's but for the most part, a GT2871R is going to be 100% dead-on reliable for the life of the engine.
What do you need to run a GT2871r? Not very much. But to make life easy...
Flange Adapter Kit - I like DiF because of the o-rings, you will save in the long-run with gaskets.
http://www.enjukuracing.com/turbo-reclo ... -9214.html
Turbo Lines
http://www.carismastore.com/index.php?l ... tail&p=358
Oil Feed Restictor
http://www.carismastore.com/index.php?l ... tail&p=288
S14 T28 Oil Drain
http://www.frsport.com/FR-Nissan-S14-S1 ... _3115.html
Engine:
HKS 740cc Injectors
http://www.enjukuracing.com/740cc-injec ... -8598.html
Enthalpy or JWT Tune
http://rs-enthalpy.com/ or http://jimwolftechnology.com/
Apexi Headgasket
http://www.enjukuracing.com/apexi-metal ... -9127.html
ARP Headstuds
http://www.enjukuracing.com/head-stud-n ... -6746.html
Boost Controller (take your pick?)
http://www.enjukuracing.com/boost-gauge ... -7001.html
DLYNNW
i got a z32 maf and aem ems now so far toward the turbo swap.
what size head gasket is a good choice and whats gone on with garrett turbos that is being argued
DuckyD
Car: 1995 240SX
http://forums.nasioc.com/forums/showthr ... ?t=1936851
Basically a formal disgruntled employee says that Garrett is more concerned with profits then qualaity, and that the turbo's being assembled in Mexico means greaater failure rate.
Borg Warner was supposed to come out with T2 internally gated turbo's designed to compete against the 2871r and similar IHI turbos, that was suppose to happen last year. Last I heard, they are going to announce them at SEMA or PRI this year.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I still haven't heard anything about Garrett turbos failing. I guess we'll soon see.
