Yeah some people bash the megan manifolds but i just can't see myself buying a $800-$1000 manifold. I have no idea how long the manifold is going to last but it has already outlasted my friends manifold which was SSAUTO Crap. Plus the welds on the megan manifold are very nice and looks very stronge. but time will tell. unless your talking about my intake manifold? lolTchouikoS13 wrote:dude, thats what i was thinking for my future setup, just different mani
what? gt turbos like any other turbo have a eff. range after that its more or less blowing hot air. a gt28r wont hurt at 20psi which is what i would say its top eff. after that you need a different turbo. your not going to blow anything up unless you have a god awful tuneLoveless wrote:your engine will blow before you go out of the turbo's peak effiency, that is the beauty of GT series turbo
I am assuming you're talking about this turbo
http://www.turbobygarrett.com/...1.htm
OK but i talked to the guys at enthaply and they told me even if i got a SAFC, i can only do +10/-10 otherwise it would mess up the tune. so i mean how much can i really do with a safc and my nismo fpr, ya know?DrifterProdigy85 wrote:Definitly a good idea. I bought my 740cc injectors from Deatschwerks and it came with a flow sheet. Breaks it down into Flow CC and Fuel Pressure. 43.5psi is 740cc while 50psi is 810cc. So you can flow quite a bit more from 550cc if you bump fuel pressure from stock. Definitly flow over 600cc which would be fine for 370whp or so. Just be sure to lean out the AFR since increasing fuel pressure will be forcing more fuel in.
With that set up (especially the enthalpy ROM) 20psi is feasable. All the time on stock internals though, not sure it'll last forever. You've got a wicked set up man. Any dyno #s?Sil80315 wrote:ah ok sweet. thanks for the info. I have this turbo on my motor now and its only boostin at 10psi and even that is pretty nice feeling. So I would be safe enough to set the boost to 20psi?
Incase you don't know about my set up
550cc injectorsTopspeed intake manifoldHKS 264 camsCometic metal headgasketARP studsMegan exhaust maniProcession GT2871RLE .64 trimZ32 MafRom tuned by Enthalpy
