Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Tue Apr 20, 2004 12:07 am
By S15 turbo housing, do you mean the turbo extension? If so, then yes it fits.
It's a good turbo...caused a lot of debate in another thread. With the .86 a/r it should be good for the mid-low 300's. It's got a T04s compressor but the back side is still small (t2) so don't expect 400hp out of it...it's too mis-matched. FYI, SR's are making close to 400 with this turbo (and every other supporting mod on the market). In a nutshell, for all out power this turbo is as good as it gets when it comes to bolt on turbos.
Note that the turbo does not come w/ an actuator. If you have an extra mani lying around, you may want to weld in an external gate and have the wastegate flapper welded shut on the GT25r. This way you won't have to worry about boost creep.
IMO, for the cost of this turbo, you should get a log top mount mani, properly sized t3/t4, and custom downpipe...you'll get more power and more room to upgrade.
