compression »
https://forums.nicoclub.com/compression-u9345.html
Sun Jul 11, 2004 7:40 pm
you dumpin the wastegate out in the open huh? I did that for a while, got really annoying. If you do decide to plumb it into the exhaust system, make sure that you use some kind of flexible tube on the wastegate pipe, they like to expand and contract with heat cycling and something will crack if you dont. I learned the hard way, at one point it was pulling on my wastegate so hard that it started leaking exhaust from the base of the wastegate where it bolts on the exhuast manifold.
Is that a stock exhaust manifold that you welded the wastegate flange to? who welded it? I have not had good luck welding to cast iron.
looks good, get some gas in the beotch and see what she can do!
