raremotive »
https://forums.nicoclub.com/raremotive-u77973.html
Tue Oct 28, 2008 11:38 am
There's fantasy and there's reality...
You have all the fantasy...
but the reality is .. a r34 front clip is expensive and hard to come by.
If you want the AWD legend. Just get the front subframe, half shafts, front drive shaft, the oil pan, oil pick up, and the 5 speed transmission. 6th gear is for cruising, and yes the 6 spd getrag is expensive. And finally... all the electronics that has to detect slip, torque and make the transfer case split the work. That would be the cheapest way to do the conversion. Then you can spend the rest of your money making your engine 500 ponies without getting the rb26. (if you really like the look of the rb26, they fit on the rb25/20 with different intake manifold)
And in the end you will be happy with your car that can go just as fast as a beef up GTR.
But.. all in all... you really are better off getting a GTR... a R32.. which is the lightest of the 3..
Just wondering... whats wrong with Evos and Subis?... or even the Porsche 911 which are AWD...and will get you laid
Modified by Rare_f8 at 2:53 PM 10/28/2008
