I was thinking the same thing, but thought the pics might have been just after having the car jacked up and they hadn't settle??superuber wrote:Your car does look clean, and I like your rims....but it would look great just a little bit lower. Are you sure it has aftermarket springs? What color are they?
I just noticed that pic clearly says Eibach on the spring! The front is actually pretty nice, with very little gap but the rear does have a slight gap. It isn't bothering me too much because of all the suspension mods it came with.superuber wrote:Your car does look clean, and I like your rims....but it would look great just a little bit lower. Are you sure it has aftermarket springs? What color are they?
Gap is unimportant. Suspension geometry and handling is what is important, unless you use your car as a doorstop.SynisterQ wrote: The front is actually pretty nice, with very little gap but the rear does have a slight gap.
