Grrr... Need some help with my PC.
As you all know, I'm not a computer nerd.
Here's the deal: My digital camera, when it unloads pics onto my hard drive, unloads them as JPG files. However, when I click on a pic and click "properties", it says it's a "QuickTime Picture".
Now - When I try to OPEN one of my pics on my HD, it asks me for some damn QuickTime file. I downloaded the latest version of QT, but it's still not working the way I want it.
My question is, is there any way to get all the pics on my HD to open with a program I actually understand? Like MS Paint or something like that?
I was advised to right-click on a pic and choose "Open With" but on my PC, I only get, "Open".
Sorry for being a computer 'tard... TIA for the helps!
lessthanjakejohn
Do you know what operating system you have?
Edit.. It doesn't matter really
Go to Start > Programs > Accesories > Paint
In paint: File > Open
In open dialog make sure "FIles of type:" says "All picture files" or "JPG/JPEG", then find your picture and press Open/OK
If you have an more advance picture program that came preinstalled than the same rules apply.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
here, ill be useful.
take one of the pics you have on your HD with the problem.
right click, go to properties.
tell me the extension. [.xxx]
DAEDALUS
Car: 1990 Infiniti Q45
I think this will work with any MS OS:
Hold the shift key down and then right-click on the file. The popup menu should have an "Open with" option, which will allow you to select the program to open the file. You can also make the program the default app to open the file with.
If shift doesn't work, try ctrl.
IvoryJ30t
the MIME file type could be incorrect or quicktime could have "stolen" the association.
Rockenreno
Car: 1997 BMW M3
AZhitman wrote:I was advised to right-click on a pic and choose "Open With" but on my PC, I only get, "Open".
That's what I was going suggest :pface
Along the same lines, here is my suggestion:-right-click on a picture, select "Properties"-the second or third option should be "Opens With:", here you can select the program which opens your pictures (MS Paint, Photoshop, Paint Shop, GIMP, whatever)
This works in WinXP, but the right-click "open with" should work in XP too, so I'm not sure if this will help. Let me know if it doesn't and I'll try to get you another way to do it. Good luck!
lessthanjakejohn
I'm pretty sure he has an Windows 95/98/ME abomination, as there are many more functions in XP for photos and there is the open with command
IvoryJ30t
open quicktime.go to the "edit" menu
go to "preferences"
go to "quick time preferences"
in the new window, there will be a pull down menu. go to "file type associations"
at the bottom will be "internet file types [gif, jpeg, ect]"
uncheck the box.
close quicktime. ms paint or viewer will default as the associated program. if it does not, then double click the picture file. a box will open and say "open with"
choose the program you want, and make sure the box that says "always use this program" at the bottom is checked.
click ok.
your done.
Rockenreno
Car: 1997 BMW M3
lessthanjakejohn wrote:I'm pretty sure he has an Windows 95/98/ME abomination
abomination indeed:mad:
w00t!
Robert's process worked (thanks to everyone else too!)
I do have Win 98. I also have a POS PC (HP Vectra PII, 333mHz), but it's the best I can do right now.
If anyone wants to "donate" WinXP to a poor NICO Admin, I'm down with that.
p.s. I set my picture viewer as "Paint". Would IE be a better viewer?
Nathan
Nah, it's a lot easier to zoom in on "details" with paint ;)
IvoryJ30t
whats you bandwidth like, i have build 2600 laying around...
Cool.
I'll stick with that.
You guys are gonna enjoy the 140 pix I took for you all at the SEMA show... Should be uploaded soon.
p.s. I learned how to use a FTP transfer program tonight, so I'm not *that* retarded. :D
IvoryJ30t wrote:whats you bandwidth like, i have build 2600 laying around...
:confused:
What do you mean?
IvoryJ30t
how fast is your connection.
i have 10Mb/sec , but if your on dialup, its gonna take all day for me to transfer the cd to you.
IvoryJ30t
i mean like*Dialup [modem, phone line]*DSL*Cable
Oh - sorry. Duh...
I have cable.
Nathan
AZhitman wrote:Cool.p.s. I learned how to use a FTP transfer program tonight, so I'm not *that* retarded. :D
Congratulations AZ, your now officially more computer literate than this 19 year old :(
IvoryJ30t
have a cd writer?
Lucent V90 DSL modem... If that means anything.
:( nope :(
IvoryJ30t
oh, its a dsl modem.
connected from the ethernet port/usb port to the modem, then to the phone line.
Yep - That's it.
I have Quest high-speed Internet access.
Nathan
Greg, go here: http://www.dslreports.com/stest and come back and tell us what it says :)
IvoryJ30t
damn, i could send the OS to you, but you need it on a CD in order to boot from it to install the os. you could also place it on a seperate partition and make boot disks, but thats complicated. if you get lost in the middle of it, youll wind up screwed without a working OS.
2003-11-10 01:52:22 EST: 497 / 582Your download speed : 497698 bps, or 497 kbps.A 60.7 KB/sec transfer rate.Your upload speed : 582241 bps, or 582 kbps.
IvoryJ30t
NY to a CA test server, i got 5839 kbps.
IvoryJ30t
not bad for DSL, it would take a couple hours. like 2. without the CD writer, its alot more complicated.
Nathan
I got 1988kbps, but hitman's still fast enough to download it in a decent amount of time, too bad he'd still need a CD of it :(
Maybe someone will hit me up with the CD at some point...
It's definitely time for a new PC. Probably gonna replace it right after Christmas. I'm looking at a Vaio with the RCA inputs and moviemaker software, as I have TONS of analog video I want to load, edit and burn onto DVD.
