YOUNG240SX wrote:it never open with the key.
ROFL, well that would have been better to mention than your original post that the trunk wouldn't open w/ the key - making some of us think something happened that caused it not to open w/ th key.
Anyway, with that knowledge, before you try the trick I mentioned, try this:
- get someone else to pull on the trunk while you hold the trunk lever by the driver seat up.
With the new info, just sounds like you have totally blown trunk struts, the trunk should open w/ 2 ppl for now so that you can replace the struts (you can search for that once you are able to open the trunk.
