philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Sun Aug 15, 2010 3:46 pm
There was a Technical Service Bulletin from Nissan regarding noises from the AWD system. Has your dealer check for this?
NTB10029 - SB Murano/Rogue; Grinding/Knocking Noise From Rear When Turning
IF YOU CONFIRM There is a grinding or knocking noise or vibration from the rear of the vehicle: - when making wide turns - on dry roads - at low speeds (under 20 MPH). ACTION Remove the Rear Propeller Shaft and test drive the vehicle: If the noise/vibration DOES NOT stop: This bulletin DOES NOT APPLY. Refer to ASIST for further diagnostic assistance. If the noise/vibration DOES stop: Replace the Electrical Coupling Assy. (CPLG ASSY-ELEC) with the one from the Parts Information section of this bulletin. Refer to the appropriate section in the Electronic Service Manual for removal and installation. DO NOT replace the entire Rear Final Drive assembly for this incident, if it should occur.
