Please email me if you are seriously interested and when you think you'll have the funds together for this. There is a long lead time ~12 weeks, and I'd like to get the order in early next month so I can start putting my motor together this summer.mtcookson wrote:That's a very awesome deal. I'm going to try getting as money together as I can for these. Any sort of dead line?
Manley produces Valves, Springs, Retainers, Rods, Pistons, Pushrods, as well as some other odds and ends. They do not produce cams.XRATED wrote:I'll take a set of rods. Put them away for a rainy day..
What other products do manley produce? Valves? Springs? Cams?
I'm on the hunt for a BIG set of N/A cams (for the missus ride) and a set of cams to use with turbos... for another project down the line.
Email me your account details and address to [email protected]
Justin Hallock
The rods will follow the design of Manley's Pro Series I-Beam rods. They are the strongest rods that Manley makes and the 4340 rods will be conservatively rated at 1000HP. Manley makes the OEM rods in the 2003-2004 Mustang Cobra as well as the Ford GT. Those rods Manley rates at 700HP and have repeatedly been taken to 1000+ HP. Just to give you an idea on how conservatively they are rated.XRATED wrote:Oh also. Are they i beam or H beam?
If need be, I'll take a set of 300M rods. I'm looking at around 1200 to 1400hp at the crank.... for one motor.
Are you in the US?
The 4340 rods sound the go then. Flip me an email for the payment details...SuperHatch wrote:
The 300M rods will be rated at 1400HP, which I can easily see taking 1800+HP.
In all honesty, we will most likely be getting 4340 rods.
Those look pretty nice as well. That makes it even harder to decide now.David Steele wrote:Minimum of 5 sets?
http://www.cunninghamrods.com/index.html
There's no minimum for Cunningham.
4340 and they make what you need (I've been quoted $1500)
Cunningham connecting rods hands down. They also use bigger rod bolts 1/2'' .mtcookson wrote:
The VQ rods have the same big end and small end diameter of the VH rods. The center to center length is shorter on the VQ rods, which can't be machined out, and the big end width of the VQ rods is narrower (21 vrs 22) which also can't be corrected with machining. Believe me, I looked at that option. I was originally going to use the VQ rods with custom pistons that moved the wrist pin down 2mm, but there is not enough meat in the piston to do this without counterweight interference and it still doesn't solve the width issue.elwesso wrote:Steve do you think it would be possible to modify VQ rods to fit the VH? Couldnt you just bore out the large end a little (assuming its smaller)
Honestly, it is very unlikely that these will be done before the summer, but I will add you to the mailing list anyway...Guishnu wrote:Hey there,I will take a set of these if they are going to be ready before the summer. My email address is [email protected]. Email me if there are any developments as i don't check these forums every day CHeersChris
I can't guarantee fitment, do you have a rod to spare?marksport wrote:Any idea if these VH45DE rods are the same as the VK45DE? The FSM says the specs/tolerances are the same.
Well, I got quotes for custom pistons from Arias, JE and a few others and they aren't all that expensive. It's just the lead time. Several years ago I rebuilt the motor in my Porsche 944, and I got a set of factory oversized pistons. Being that the 944 use an Alusil block and no one really did sleeving back then, I didn't have much of a choice. The factory pistons are made by Mahle, and in comparison to the custom aftermarket, I believe the custom ones are higher quality. Many of us know that Mahle are very high quality pistons already and think the same can be said towards the factory VQ30DET pistons. In terms of cost, The set of 4 pistons that I bought for my Porsche from the dealer cost nearly twice as much as the quotes I got for the set of 8 custom pistons. It took about a month to get them as the parts guy told me in 20 years, this is the second set they have ever sold, and due to the cost and that the car is no longer made, Porsche NA would not stock these in their distribution warehouses. I later found out that it would have been cheaper to replace the motor with a used longblock. I don't necessarily need the rods as much as the pistons but if this group buy is $1150 for a set, that's nearly 1/2 the price of some of the quotes I have gotten with similar finished quality. I believe in overbuilding the motor for reliability.Mettler wrote:So if you're using rods with the stock dimensions, what have you decided on as a suitable decompression piston that just bolts in? My suggestion would be perhaps to have these rods made to be compatible with VQ30DET pistons, saving the additional cost of a custom aftermarket piston.
