Group Buy Feeler: AMS/Turbo240 Fully counterweighted Crank
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
spooled240 wrote:Just out of curiosity, if the srt-4 has a fcw crank, why would redline be at 6000rpm? Turbo maxes out?
Correction. 6790RPM redline, but it makes more power than most 4 bangers within it's limited RPM range. It's also limited to it's redline from it's massive stroke..Stroke on the SRT-4 is 101mm, stroke on the KA24de is 96mm.Bore on the SRT-4 is 87.5mm, KA24de's bore is 89mm.Stroke is what limits redline, not piston bore.The KA's stroke is at 96mm so it will get considerably more rev, than an srt-4 engine, 5mm stroking distance in a crank case is a huge difference.
Journal diameters is the only other issue that causes redline indifferences from friction.
eazye2000
Car: S13 KA-DET
All this cool stuff that AMS comes out with after I build my motor... Dang it... Dang it to hell!I would be more than willing to build another motor, but I almost got a divorce from building my last KA... lol
spooled240
Car: kouki s14
no man it redlines at 6 grand, lower than our factory ka redline. But yeah stroke does really hamper the high rev capabilities. I maybe suspected that dodge was playing it safe so they wouldn't get so many srt-4's under warranty with spun bearings and thrown rods in their tech shops lol...
I would consider it maybe if i was pushing 500rwhp, but in my hp range i don't think it is much bang for the buck...
Bigvinnie
I dunno know about that, the specs claim that it redlines to 6750, I claimed 6790 so I am a tad off.But it makes a crap load of power at 5300RPM @230HP to the crank...I've never seen so much torque produced so early in the rpm range @ 2200RPM it makes 250FT/LB.s of torque!!! Thats freakin amazing if thats what it makes at the factory specs.http://www.modernracer.com/dodgeneonsrt4.html
I did happen to pull a couple of dynoe's and power does drop after 6200RPM, so why they rate redline at 6750 baffles me. Massive torque band for a 101mm stroker. The engine also makes 500WHP on stock internals, an SR can make roughly 420WHP on stock internals, and the halfwieghted KA makes about 380WHP on stock internals. So the crank does help with power output although it isn't making a lot of rev with it's huge stroke.http://videos.streetfire.net/v...D.htmh ... m/....aspx
This turbo magazine article confuses the piss out of me. They keep calling it a 2.0 liter, but in every pic they show it's a 2.4 liter engine. Per bolt on and mod it makes pretty good numbers.http://www.turbomagazine.com/t....html
Any hoo, I would think the KA24de is better in comparison to the K24a Honda engine. K24a has a 99mm stroke, 87mm bore (fully counterweighted) @ 2354cc's, and can make power up to 7000RPM.Ka24de at 96mm stroke and a 89 mm bore has 2389cc's.I think these 2 engines would be better in comparison than the Dodge engine.
Modified by Bigvinnie at 4:46 PM 8/1/2007
480sx
Car: 1996 Pearl White 240sx
Well i want in on the group buy, send me information at [email protected], or post it here.
Chris@AMS
Car: 91 Nissan 240sx
Here is the thread, on our forum, which I will be keeping official track of the people who are in the group buy and all information pertaining to it.
http://www.turbo240.com/forums...#4932
Quote »This is the official group buy thread for the fully CW crank. All updates on this crank will be posted here, instead off ALL of the forums this was posted on.
Here is the pricing for the Cranks Single crank, $1600 + ship 5 People, $1400 + ship 10 People, $1300 + ship
In order to be part of this group buy a deposit is required. I will need $700 down in order to place you on the list for the group buy.
The confirmed details of the crank are as follows.
Nissan KA24 Crankshaft 4340 (fully machined billet) 96mm stroke Fillet Radii: .125" Connecting rod pin width: .950" Rod Pin Diameter: 1.8884 +/-.0002" Main Journal Diameter: Stock Factory Size If .760" wide bearing is used, a .031" chamfer will be required on each side of bearing Oiling method: Straight oil holes (each rod recieves its own feel from a main journal)
Expedited Air Shipping is $65/crank
Here is the list of people that are in on the group buy.
1. 2. 3. 4. 5. 6. 7. 8. 9. 10.[/quote]Thanks!
Bigvinnie
Spoke with Brian Crower personally at yesterdays Formula Drift @ infinion raceway. He will too be selling a stock stroke (96mm) fully counterweighted crank for $1800. AMS has a deal I wouldn't pass this up.I also asked Brian if his stroker kit has been dyno tested, his company doesn't even have an engine ready with that kit yet for results. When I asked about the redline of the stroker kit it should redline somewhere to what the srt 4 engine red lines. SRT 4 stroke is 101mm, the KA24de stroker kit would be 102mm stroke. Just some info directly from the source.
