nissanfanatic »
https://forums.nicoclub.com/nissanfanatic-u21678.html
Mon Dec 19, 2005 6:50 pm
I love it! Definatly not a good boost controller if you want something that is easy to set up tho. You will be adjusting settings for the rest of your life.lol
But if you want something that is infinitely adjustable, then this is for you. It has datalogging, so you can make adjustements based off of that. It has gear based duty adjutment, Feedback speed(so you can build boost quickly in low gears), scramble mode(wire in a switch and overboost using that), two separate boost settings+off where you use only spring setting, and on and on and on.. ITs awesome! Read up on it!
