grounding
jpnissans13
Car: 1991 s13
hey i read the article about the grounding wires. i just have one simple question. the guy used 2g wire will it make a difference if i use like 8g? and if it does make a difference.. in what way? thanks
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I think I remember reading in a magazine about the thickness of the wire being better at conducting or something.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
thicker the better, a good premade wire to use are the red lawn mower battery grounds they sell in discount auto parts, they come in 12 18 24 inch lengths, 3-7 bucks depending on length, make sure you ground the block to the frame
jpnissans13
Car: 1991 s13
is it ok if i ground it to firewall?
ReX2SX
Car: 240sx
Anything on the frame.
W/ wire the ting to remeber is you can also go bigger but you cant go smaller. The longer the wire is the more resistance it has.
jpnissans13
Car: 1991 s13
resistance to what? im not familiar with all them electrical things that much
ReX2SX
Car: 240sx
Resistace to elecrtical flow.
Check to find out what gauge your wire is factory. A diagram should tell you. Dnt go smaller.
Think of water in a hose. There is more water pressure in a 8ft hose than 3ft hose if its the same diameter if the same amount of force is being applied behind it..
Same scenario, if the 8ft hose was widened, in theory, the same amount of pressure can be the same as that of the 3ft hose.
EDIT:Fixed Scenarios..Amps=pressure Volts=Force push Amps(pressur)
Modified by ReX2SX at 12:39 AM 12/26/2008
jpnissans13
Car: 1991 s13
thanks! ill go check what napa has and ill post up some pics latter!
